doesn't login into web client
Cees-cx
Hi All,
i dont know what to do next.
first i have try reset password. i got the mail with the link. then reset password. but when i try to login again. nothing happend. it looks like refresh from the website.
i have try with chrome, firefox, edge. all the same.
and this is with all the users account
but when i give the wrong login name or password i do see response :)
I have have root cli access. im newbie with linux commando
linux version 3cx
3cxpbx:
Installed: 20.0.6.724
Candidate: 20.0.6.724
Version table:
20.0.7.890 1
any help is welcome
thank you in advance
Cees
Use the extension number or email address as the username.
Best,
KS.
Maybe you have IP restrictions/blacklist up? Can you try from within the same LAN as the PBX is sitting in?
Sure i will try that. That will take sometime. I will let you know
i did try that. the same result. page refresh without any msg or error
try it with extension number or email address
do you know, is there away to disable restrictions/blacklist on the cli. i know i have this running. but as far i know all the rfc 1918 ip are allow
Are other users logging in OK?
Did you reboot the system to see if the issue clears?
yes i did.
i found article online to check the DB. nothing in the blacklist for our ip range.
Im now starting a new install. next to the running 3cx. just to see if i cant access and with the backup restored. what i can see
This wont work next to the running old pbx!
hi All.
thanks for everything. after install and import the backup file from 1 year old. everything look okay. i have GUI access again. and also admin.
phones did reboot but works fine.
i have no idea what is was. i think it have to with restrictions/blacklist and in this backup the list is still empty :)
again thanks for all your help
Reactions: KyriacosS_3CX
LeeonLau
