Downgrading PRO trial version to standard
DDave
Forum User
Hello! I need to prepare a dummy 3cx for a company to show, they basically need a standard instance with the least amount of sim. calls so that they can give the clients a demo of the management page and such.
Problem is, when you get a free version of 3cx you automatically get 30 days of free pro, adding functions that i currently don't want. How can i downgrade to the standard version?
You cannot downgrade it unfortunately, it will be done automatically.
Simply avoid using those features which you can see compared here
https://www.3cx.com/ordering/pricing/
You can explain that to the customer, and also let them know they can upgrade in the future if they wish to do so.
Reactions: DDave
Ok, thank you
3K8iMGWviZ
