Download
donovanpl1231
Hi All,
Under download on the Elastix.org site, listed as a main heading is "Elastix PBX Appliance Software".
Then under that listed is "Elastix 2.2.0 Stable", and others.
Are these downloads for a particular "Appliance"? Or, are will they work on any machine providing the drivers are embedded in the load?
Thanks in advance.
The "Elastix 2.2.0 Stable" is similar to any Linux distro out there, you can install it in a regular PC, but keep in mind the requirements of your environment for choosing that PC.
On the other hand, check also the certified hardware:
http://www.elastix.org/index.php/en/pro ... dware.html
Regards,
Claudio
CLTedu
