Downloading recordings - slow fetch to API
Martin N.
Hi all,
I have 3CX Version 20.0 Update 6 (Build 724 Release). I need to download automatic recordings via caller number and time of call. I'm using API for fetch calls.
First one for new calls - /ReportCallLogData/Pbx.GetCallLogData - working fine.
Second one for old calls before update - /ReportCallLogData/Pbx.GetOldCallLogData - is very slow for me - 1min - 4min.
I calling API like this
/xapi/v1/ReportCallLogData/Pbx.GetOldCallLogData(periodFrom=2025-07-25T13:27:15.000Z,periodTo=2025-07-25T14:01:47.000Z,sourceType=0,sourceFilter='',destinationType=0,destinationFilter='',callsType=0,callTimeFilterType=0,callTimeFilterFrom='0:00:0',callTimeFilterTo='0:00:0',hidePcalls=true)?$top=100&$skip=0&$search=%6662495368666%22&$orderby=SegmentId%20desc
Is some possible way how to speed this up?
The old endpoint is slow and will always be slower due to the amount of queries done in the backend. That's why the new one using the new CDR table is much faster. Everything is in one or two tables, instead of almost 10.
Query smaller date ranges for faster speeds. That's the only workaround.
Reactions: Alejandro_3CX
I have a small range: periodFrom=2025-07-25T13:27:15.000Z, periodTo=2025-07-25T14:01:47.000. Can I use the API with different values and filters to speed up the process?
Hassan Murasan
