Solved Downloading wrong version of Desktop App after the last update
Vasilis_PHS
After the latest upgrade (ver. 18.0 Build 939), when I go into the web client to download the windows app and provision it downloads version 16 desktop app and a config file to provision.
Is the Desktop App already installed on you rmachine?
Because of remote access, I have some laptops that I give to users. Depending on the user, I also do the provision in desktop app, which I can't do now. As I told you, when I press provision, it downloads a config file which does not work with version 18.
Sorry for my English.
Are you sure you tried to download the Desktop App and not the Windows App? The last one is the old legacy app.
Yes, normally you should see the below:
The Windows App is the legacy and it will download the config file. You need to select the Desktop App
Reactions: bitn2
You are right, I was actually trying to download the windows app and not the desktop app.
Thank you all for your help.
Reactions: bitn2
Glad to assist ;)
Jake_Southern
