Dsktop App comand line parameters
Paideia
i was wondering if the new Desktop App supports command line parameters on launch. I would like to give the app a different configuration directory instead of the default C:\Users\%user%\AppData\Roaming\3CXDesktopApp
Thank you in advance
Hi!
I'm not aware of any variable you can pass as an argument that will change the directory it looks for the config in.
Could you explain though what exactly you want to achieve?
Our call center users have 1 shared account on a terminal server so when one session opens the app the other ones can't use it because the Roaming\3CXDesktopApp files are in use i would imagine. I would like to give the exe an argument like -config:C:\Users\%user%\AppData\Roaming\%CLIENTNAME% so the app generates a different folder for each hostname connecting.
ps. we already use such a method with Google Chrome for example.
Thank you
I see, in that case I can't really think of an alternative suggestion, as I said, I'm not aware of an argument that you can pass to do what you mentioned with Chrome as an example.
megalmazan
