DTMF dial tones dont register
Terry.Tey
Forum User
Using windows 3cx application
trying to dial test to uk on these numbers below are fine, its when the automated system asks to press numbers for options is when it doesnt register the keypress.
UK Webex: +442081181016
Clydesdale telebank: +441419517320
RBS telebank: +441315498888
3cx Version : Professional Annual 16.0.612
Server OS : Windows Server 2012 R2 local hosted
3cx phone client system v 16.3.0.144
Trunk provider : vibe, gateway 13.1.33.67
local provisioning
custom templates yes
only 3cx Media Server failed and port range of [10600 to 10998] failed, not sure we use those ones (zipped doc attached)
It could be a port issue, but then you would have one way, or no audio, not just no DTMF. I would suspect that it is an incompatible DTMF Method setting, on the set(s) you are using. Have you tried more than one set, or type of set? 3CX App? Have you checked to see what is supported by your provider?
If you call other numbers, like your mobile, or home phone, are you able to hear the DTMF tones sent from the PBX end?
yeah tried dialing to my mobile, i can hear the keypress dial tones from my mobile.
Ill have to check the DTMF Method setting with regards to sets.
Are you finding that you are unable to use any external service that requires DTMF, or is it just some? I'm assuming that access to 3CX voicemail options (internal DTMF services) is working correctly.
[email protected].
