- Joined
- Jul 3, 2017
- Messages
- 184
- Reaction score
- 12
Following this thread https://www.3cx.com/community/threa...hones-use-rfc2833-provider-uses-inband.80787/ we have upgraded our 3cx (Enterprise Annual license) to v18 (Build 1880).
Our SIP provider is Vodafone (Greece) and they only accept DTMF as inband.
I have set up a Fanvil X4U IP phone to use DTMF inband, and placed a call to PSTN (Vodafone) from that IP Phone.
So the call flow is:
Fanvil X4U - - > 3cx V18 - - > Vodafone (SIP)
I took a Wireshark trace, debugged the RTP and noticed the following:
Fanvil sends DTMF as inband to 3cx
3cx sends DTMF as RFC2833 to Vodafone
Since Vodafone only supports inband, the outgoing DTMF fails.
Why has 3cx detected the Vodafone SIP Trunk to be using RFC2833?
If this helps, the same IP phone (Fanvil X4U) is also used to open the office's door phone, Fanvil i20S. That door phone only accepts RFC2833. The IP Phone is sending inbad to 3cx, and 3cx is sending RFC2833 to the door phone. So, this scenario (opening the door with DTMF #1) works. But we are having issue with all DTMF digits sent to PSTN.
Thank you,
George
Thank you,
George
