Solved DTMF Issues
greychain
Gold Partner
  • 3CX Version, Standard Pro16.0.6.655
  • Server OS, Debian 9
  • Is the 3CX Server Hosted and where? Self
  • IP Phone Make/Model/Firmware - webclient
  • Provisioning Method: Local / VPN / STUN / SBC Local maybe
  • Trunk Provider or Gateway Make/Model Provider not supported
  • Has the Firewall Checker passed: YES / NO mostly
I'm making an external call and can see the system is getting DTMF.
The system will not connect me to the extension that I request ie 002.
If I make an internal call to the same DR and press the desired extension it works.
Any thoughts?
Turned out to be a firewall issue. There was a VOIP inspection on the firewall that magically got renabled.
Magic can be so frustrating sometimes ;)
Reactions: ClaudioBassani
EMMEPICASA
