DTMF tones are not being registered with called party
contoured_solutions
Greetings!
I have 3CX v20 instance in which a user who places calls over the web app says that she cannot get interactive voice menus to recognize her key presses. In doing a little research, I saw that there were a few options in the trunk that could be modified to potentially fix this issue (options like Support Re-Invite and PBX Delivers Audio). Is there a way to modify these options in v20? Are there any other suggestions for fixing my primary issue in v20?
My trunk provider is Bandwidth.com
I would fist check to see what DTMF Method is being used, and, if INBAND, which Codec. If another extension is called, and a key is pressed, can the DTMF tone be heard, what about when calling an external number?
How do I determine which DTMF method is being used?
This will be between the device sending the DTMF "information", and your provider which takes that, and passes it on.
See....
arming
