Easy way to add Sentiment Scores to Hubspot Call Journalling
CPMM
Platinum Partner
Does anyone know of a simple edit to the default Hubspot CRM template that will allow logging the Sentiment Score to Hubspot. I tried just using the word [Sentiment] in the parameters for the logging, but this does not seem to work. I am guessing that perhaps an edit is needed to the template.
Is this something simple to do?
Any advice gratefully received.
It's not in the variables and there's no way to add that ourselves. Not sure why it was never added.
@N_G could it be added? We already have Summary, Transcription and RecordingUrl. SentimentScore would make sense.
Face the same issue / need :)
Applies to any integration actually.
Thank you !
Thank you !
It's been added in U8 Alpha/Beta.
[Sentiment]
intoxtech
