Easy way to update every users email address?
cam
Hi, we having a rebrand so want to change everyones email address in 3cx.
Is there an easy way to achieve this?
Export your users, then in the csv file make the changes and import them back in
Cool, I was hoping it was that straight forward.
I think you'll need to delete your users and then import, which has a bunch of consequences (resetup VM, phones, queue membership, etc)
Unless something has changed, import is not update, only create.
My mistake, I think you are right
that was what I was afraid of. we will do them manually. Thanks SweetAction!
Glad someone told you about the reconfiguring of queues and such, i made this mistake one time :D
lastshadow
