- Joined
- May 18, 2021
- Messages
- 68
- Reaction score
- 20
Hi Everyone,
Info:
We are having a wierd issue with a single client that I cannot really explain.
I was hoping someone had a simmilar issue in the past and could point us in the right direction.
Issue:
A Single user has to change a few settings on his PWA app every day.
In this case it's "Show unregistered extensions" and the headset integration.
The unregistered extensions checkbox needs to be turned off every day and the headset integration goes to None.
We have missed calls this way because with the headset integration set to none the headset has some wierd behavior with the PWA app.
It will pick up the call automatically but then when you pick up the headset from its dock it will just end the call.
Troubleshoot steps taken:
steps to reproduce the issue:
Any help in the right direction would be greatly appreciated.
Thank you
Info:
- Version 20.0 Update 3 (Build 806 Release)
- Self hosted | On Premise
- Browser: Edge
- App type: PWA
Issue:
- Cleared & reset browser
- reinstalled PWA app
- Change the settings
- Reboot the laptop
- Settings go back to their default state.
Thank you
