Elastix 2.2 RC1 Asterisk syn-floods 192.168.0.24
kinglyr
Dear friends,
I noticed the following unwanted packets on my firewall log
Description of problem:
Version-Release number of selected component (if applicable):
Elastix 2.2 RC1 on x86_64 (Asterisk 1.8.5.0)
How reproducible:
Every time
Steps to Reproduce:
1. Install Elastix
2. check your firewall log to see the syn flood
Additional info:
1. The problem is the sample /etc/asterisk/res_pktccops.conf. It contains entries
which by default contact 192.168.0.24. The extra neat thing is that this
affects even upgrades, because the file does not exist in older versions of
Asterisk...
2. Also the conf file contains 2 times the same configuration!!!
I caught this in my testing environment, it would have been no fun at all in
production.
A. Proposed resolution: (taken from https://bugzilla.redhat.com/show_bug.cgi?id=658431)
When building, sed -i -e 's/^/;/' /etc/asterisk/res_pktccops.conf
B. proposed resolution: (by kinglyr)
edit the /etc/asterisk/res_pktccops.conf
and replace everything with the following: (settings taken bug thread: https://issues.asterisk.org/view.php?id=12950)
; Sample res_pktccops.conf
; created 4-9-2011 by kinglyr (GR)
;[general]
;gateinfoperiod => 60 ; default 60s
;gatetimeout = 150 ; default 150
;t1 => 250 ; default 250s
;t7 => 200 ; default 200s
;t8 => 300 ; default 300s
;keepalive => 60 ; default 60s
;[test]
;host => 192.168.0.24
;pool => 10.0.1.0 10.0.1.255
;pool => 10.0.3.0 10.0.3.255
;pool => 10.0.7.0 10.0.8.255
;pool => 10.0.10.0 10.0.11.255
[general]
[test-cmts]
host => 10.0.0.1 ;PUT HERE THE IP OF YOUR ADSL ROUTER
Hi kinglyr. :)
Did you sent this issue into bug report?
However, this module seems made for MGCP channel, right?
Hello danardf ,
No i have n't. Can you send me the link to post it there?
Yes it is for MGCP channel...
Regards,
John
CLTedu
