Elastix as a local portal
maxioml
Hello Everyone!
I have a great idea about my Elastix box, I want to make it local portal.
Basically I want start from easy staff:
1. Edit current pages and add some new features/buttons/etc;
2. Put in Elastix all my internal web services;
3. Create proper integration with LDAP.
Can someone give me a clue where I can make changes, f.e. I want to add time filtering parameters in Monitoring Tab.
Cheers,
Maxim
All the elastix modules are located at: /var/www/html/modules/
If you want to know the name for a specific module, you may go into that module and check the URL from your browser, you see the following: index.php?menu=monitoring
Another could be, that you send an email to [email protected] requesting such customizations.
CLTedu
