Elastix DAHDI Proxmox Setup
FreshConnexions
I am trying to setup DAHDI on a Proxmox Server to provide timing capabilities for Elastix VPS that will be hosted in containers on the server.
I found this old post which i used as a guide to get me started:
http://www.elastix.org/en/component/kun ... ox-15.html
DAHDI appears to install ok however when i start DAHDI i get the following errors:
proxmox1:/usr/src/dahdi-tools-2.6.0-rc1# /etc/init.d/dahdi start
Loading DAHDI hardware modules:
WARNING: Error inserting crc_ccitt (/lib/modules/2.6.32-6-pve/kernel/lib/crc-ccitt.ko): Invalid module format
FATAL: Error inserting dahdi (/lib/modules/2.6.32-6-pve/dahdi/dahdi.ko): Invalid module format
wct4xxp: error wcte12xp: error wct1xxp: error wcte11xp: error wctdm24xxp: error wcfxo: error wctdm: error wcb4xxp: error wctc4xxp: error xpp_usb: error
Error: missing /dev/dahdi!
The instructions on the old post refer to Proxmox 1.5, Proxmox is now at version 1.9 which is the version i am attempting this install on. Has anyone sucessfully carried this out? Could you point me in the right direction to get it up and running please.
CLTedu
