Email voicemail not working in v18 alpha?
ElementalWindX
Did something with the way the pbx emails voicemails change in 18.0 (Build 1379)? I'm no longer getting email notifications for voicemails.
If so, how do I fix it?
Thanks.
Hi @ElementalWindX,
Have you ensured that the extension has the correct email address associated to it?
Ensure that Enable Voicemail >> Email Options >> Have the option to send the voicemail via email.
Does the test return a positive result when checking Settings >> Email >> Mail Server >> Test. Which "Type of Email server" have you selected?
zipman
