Solved error record(zoho integration)
HiroNikuyama
Hi, Thank you for your support.
Now, in an environment that is integrated with zoho CRM, the log /var/lib/3cxpbx/Instance1/Data/Logs/3cxSystemService.log records the following string for every call.
System.Exception: Server returned a non successful status code - HTTPStatusCode=BadRequest - Reason= - Content={"code":"INVALID_QUERY","details":{"reason":"the field is not available for search","api_name":"extension"},"message":"invalid query formed","status":"error"}
On the page 'Test CRM integration' it seems successful when attempting a test.
So I can't assume what is the problem and where should be amended.
Please kindly advise me.
best regards
Reactions: edossantos
