Error when trying to execute PowerShell script dial plan
Jordan351
SOHO User
Hi there,
We're trying to activate TeamsDirect Routing with the PS script teams_dial_plan.ps1.
After connecting to the tenant and executing the script, here is the error code:
Set-CsOnlinePstnUsage : Cannot add these items to the collection as they conflict or have duplicate key/identity:
Usage: 3CX PSTN Usage
I don't understand if the issue is from 3CX, Microsoft, or maybe the certificate.
Has someone already encountered this problem?
I have a 4SC license. Is it compulsory to have a 16SC to use Teams Direct Routing? That seems weird to me...
I appreciate your help.
Best regards,
Jordan
Make sure you don't have any remnants of previous config in Teams. Go in Teams Admin and delete any voice routes, PSTN usages, SBCs, etc.
Thank you for your answer.
I already tried to remove everything in Teams admin panel
I also checked the Teams Integration FAQs and used these PS commands and deleted everything but Global:
Get-CsTenantDialPlan
get-CsOnlineVoiceRoutingPolicy
Get-CsOnlineVoiceRoute
Get-CsOnlinePstnUsage
get-CsOnlinePSTNGateway
All clear, only Global is still there.
I executed the script again and I got this:
Set-CsOnlinePstnUsage : Cannot remove these items from the collection because they cannot be found: Usage: All
Au caractère C:\teams_dial_plan.ps1:6 : 1
+ Set-CsOnlinePstnUsage -Identity Global -Usage @{remove="All"}
+ CategoryInfo : InvalidOperation : ({ ConfigType = ...Configuration }:<>f__AnonymousType106`5) [Set-CsOn
linePstnUsage], Exception
+ FullyQualifiedErrorId : ClientError,Microsoft.Teams.ConfigApi.Cmdlets.SetCsOnlinePstnUsage
SBCs with issues: 1
Status: Inactive
Thanks for your help,
Jordan
Do you think this could be because the subscription is 4SC instead of 16?
I'm really having trouble solving the problem.
Stephan Eusebe
