esxi vmware auto start
bennuss1
I am running the debian version of 3cx on vmware . the only issue i have is if the server goes down the auto restart that works well with any windows vm or a regular linux vm doesnt work. Is there some modification or setting that i need to do to get it to work?
I have Autostart running for 5 VMs including 2 SBCs and it works well
What's your OS and did you install open-vm-tools?
I am runnjng the custom 3cx iso. on esxi. i believe it is debian based. they say if you instll anything then you lose support. can i install vmware tools
You should be able to. Just SSH into it and run "apt install open-vm-tools" then reboot the VM. It will help a lot to make the ESXi work great with it.
What version of ESXi are you running too?
I did this. the autostart still doesnt work
i am on 7 . I just turned it on. didnt change any of the defaults
Send me a screenshot please. If by default, VMs start 120seconds after the system is booted.
Code:
apt-get install open-vm-tools
To Install VMWare Tools, SSH into to VM and run this command as root
swegner
