"Etc/Unknown" was not recognized as a valid Windows time zone ID.
[email protected]
2 week old 3cx system running in Azure. Starting today when i click "call log" it returns the error :
once i hit ok the call log is blank with no results.
Hello @[email protected]
What OS is the PBX installed on? Also what is the timezone set in the PBX / Settings / Timezone and what is set as the machines timezone?
as stated above its running in Azure, so guessing linux in settings its set to Mountian time.
If you navigate to Dashboard, you see a Terminal button under the PBX Status column? Was the PBX installed using PBX Express?
I do see the terminal button. It was installed with the PBX Express.
Do you remember the timezone you selected during the installation with PBX Express? Also what is the timezone set in Debian You can look this up by accessing the OS of the instance and typing "timedatectl".
I set it up with Mountain Time. How do i access the OS of an azure based system?
BIT Incorporated
