Event log flooded with Parser error for LINE variable
briankayser
I upgraded from 14 to 15.5 then to 16 over the weekend.
My event log flood get filled with these errors every 2 seconds:
3CX Template Parser ID: 30025
Unknown variable '%%Line%%' in template yealinkT2X-Custom.ph.xml at position 48182
Why would it think LINE is unknown? Since it is in most templates (like 700+ times in a single template) it just spews these out. It is not just one template. I see it in yealinkT4x.ph.xml and others also. I tried deleting the template from the hard drive and then it added it back in from default, I'm assuming; and started tossing the errors again.
Any ideas?
Bluebox Global
