EveryoneAPI firing open tabs again
SethTalley
Are you using the Chrome Extension as well? You will need to turn this off for the extension as well.
Where can I configure that? I looked last night and didn't find it.
In the 3CX Web Client > Settings > Integration > Off.
In the Chrome Extension, go the the menu on the upper left corner:
Then go to Settings > Integration > Off:
Thanks Ernesto. She had turned the extension off and turned it back on again, which caused the popup not to fire.
Reactions: edossantos
postmaster@studiolegaleda
