Example to Call Flow to collect the call details at the end of the call and send to database or webservice
noob-integrator
New User
Any Example to Call Flow to collect the call details at the end of the call and send them to a database or web service
  • I know there are components for both database and web service in the Call Flow Designer.
  • What I don't know is what are the possible fields related to the call are available??
  • Like, as data/fields similar to CDR (Call data records) found in the CSV file.
  • On a side note, do you have any recommendations on using CDR or Call Flow to collect the call information?
Reactions: Christophe DaSilva
The CFD cannot monitor calls made elsewhere on the system.
Also, what you're looking for is either the CDR or the CRM Integration.
Thanks!! I didn't know CFD only works with Inbound calls.
Reactions: VoIPTools
It can also make calls (dialer) but yeah, it cannot be like an app monitoring calls, for that you need event-based APIs like @VoIPTools.
Does VoipTool work based on CDR? Or database access?
We offer a couple of approaches that could work for you. Perhaps the easiest option is our 3CX Exporter tool. You can configure 3CX to create a simple text file that summarizes each phone call (I suggest configuring 3CX to create a separate file for each phone call). Exporter can grab these files, in real-time as they are created, parse the information, and place the data in a SQL / MySQL database.
Alternatively, we offer a real-time events API (.Net Framework / .Net Core) that makes it possible to subscribe to phone call events as they take place -- allowing you to take appropriate actions. This is a programmer's tool rather than a end-user tool.
amazingbv
