exclude extension from being listen to
Thomasni
Forum User
We have given 2 extensions the right to listen to other calls.
Now, these extensions can listen to every call made from every extension.
Is it possible to block extensions? so that it is not possible to listen in on these extensions?
Hello @Thomasni
Have a look at "Group" Tab. Do you have any group else than the default group ? That's here you separate rights between users
travislogixal
