Exlude ring group calls from parallel ringing on mobile
phoyer
Is there a way to receive calls from ring groups on the normal extension but not to receive them on the mobile phone if parallel ringing is enabled?
To answer your question, no
Any workaround? I suppose I am not the only one who prefers not to receive group calls on the mobile also because on the phone you cannot tell if it is a direct call or a group call.
You could send the name of the ring group, even a couple of letters/ letter & number, to keep the entire name short. then you'd know if it was a direct call, or a ring group call.
How would I do this? As far as I can see, ring groups do not have a CLI modification option and so I would always see the calling party number.
hughesdouglas
