Expired publisher certificate
richiewhite
Platinum Partner
Hi team, we've had a client reach out to us requesting a new copy of the desktop client MSIX as the publisher certificate has expired today on the copy available at https://downloads-global.3cx.com/downloads/3cxsoftphone/3CX.msix, linked on the partner portal download page. Is 3CX able to set up a new version of the installer with their new cert when possible?
Hi thanks for that. The new build V5.5 will be online shortly. Will keep you updated
@richiewhite try again now please. We have updated the msix to the latest/
Might require some time to rotate
Reactions: matjaz
Hi Thom, thanks for the update. I just downloaded from https://downloads-global.3cx.com/downloads/3cxsoftphone/3CX.msix (link in the partner portal) and it looks to still be the older version, I guess that's cached however. Will try later.
One question, another partner I work with will be raising a support case about this, is there any way to ask for newly signed installers for older versions? A specific customer requires a newly signed installer for 20.0.664.0 as they have not tested, or have the time to test anything newer.
@ThomB_3CX we also have a large deployment dependent on this, and an update to confirm a timeline for the fix would be greatly appreciated. Many thanks.
Reactions: PaulC_3CX
@gazeuxbaveux Thank you very much for your effor. I also tryed to export it from the Microsoft Store already. But it is not the same version we had - Users would need to register freshly...
Not a solution for us, as we have a lot of users. We need the same old App with a new certificate.
@gazeuxbaveux Merci beaucoup pour vos efforts. J’ai également essayé de l’exporter depuis le Microsoft Store. Mais ce n’est pas la même version que celle que nous avions — les utilisateurs devraient se réinscrire…
Ce n’est pas une solution pour nous, car nous avons beaucoup d’utilisateurs. Nous avons besoin de l’ancienne application avec un nouveau certificat.
Hello ThomB_3CX, is there any official statement from 3CX regarding the issue?
Is there an investigation underway?
Is work being done on the problem, as well as on the related issues described in my post?
No communication is bad communication.
Should we open a case for this?
My Thread -->
3CX MSIX App – Expired Code Signing Certificate since 29.03.2026​
@ThomB_3CX can you please provide us all with an update on this issue. I can see that I am not alone in the need for this to be resolved asap, and pressure on our client base is now growing. It would be greatly appreciated if you could acknowledge that the problem is being actively worked on and provide an ETA. Many thanks.
We have achieved a workaround while this issue persists, we have extracted version 20.0.1096.0 MSIx from the windows store, which contains a valid certificate.
We ran this command first in Powershell (Admin)
Add-AppxProvisionedPackage -PackagePath "C:\users\Username\documents\3cx.msix" -Online -SkipLicense
Then installed the MSIX, now have a working 3cx app.
Hope this helps.
We would like to inform you that a new version of the Softphone application (MSIX) has been released and is now available for download via the Partner Portal.
Please note that this version is not supported on Windows 10, as the operating system is end-of-life.
saw-nick
