Export Blacklisted Numbers (not IP addresses)
skalf
Is there a way to export the blacklisted numbers' list that I have created over time? I want to share it with a friend and I can see only an import button, no export!
It is under /#/app/settings/number_blacklist, just to make sure I am not talking about IP addresses.
3CX v16.0.1078 self hosted on Debian.
Thank you in advance,
/skalf
Hi @skalf,
We currently don't have that as an option in the Management Console. As I've not been able to find this within the Ideas section, may I suggest contacting a 3CX Partner (Gold and above) to add it to the Ideas section?
Hi Vassili,
Is that an option with some other software or maybe a file that I can copy from the filesystem? I will contact a friend who is certified and works at a partner but I don't know their partnering level with 3CX, hope they are above Gold.
Thanks again,
/skalf
Reactions: NickD_3CX
florentrobineau
