Export Contacts
SSCC
Dear All,
When I am connected to the Management Console I click on Advance > Contacts - I can see a few contacts and able to export these contacts
However When I log into the Web Client, I have many more contacts, but there is no way of me to export the contacts.
Can someone advise how to extract all contacts from the webclient.
Thank you
You cant export your private contacts... Take a backup and have a look for the user in the xml file... ther you will find the contacts.
Thanks would that be a backup from the Management Console or the user web client ?
I don't see any option from the user web client.
From the management console, the normal 3cx backup..
Do you know what to look for, I searched for users but cannot find anything.
The xml file on your screenshot is the file to go.
Teemal
