Solved Extension modification - "mobile number not set"
Alphabetic
3CX MVP
So i've just gone in to change a BLF and it's forcing me to enter a mobile number.
is there a setting i've got enabled in my ext that would force me to put this in?
I have no forwarding rules set up to mobile.
Yes there is, basically anything on the extension level that uses that mobile number.
Check for:
1. the "Ring my mobile simultaneously" setting under the Available and Custom 1 profile statuses.
2. any "Forward to Mobile" forwarding rules in All Profile statuses.
Check for:
caused by option 1.
thanks.
Reactions: ChrisC_3CX
devo.it
