Extension status change
Trestill
Platinum Distributor
I found old post showing how to change extensions status (available, away, etc.) in CC API and I would like to know if this is still accurate:
Code:
var ext = PhoneSystem.Root.GetExtensions().FirstOrDefault(f => f.Number == "001");
                    if (ext != null)
                        ext.CurrentProfile = ext.FwdProfiles[3];
                        ext.Save();
This one is supposed to change status to Away but I found that in my case different extensions have different order of statuses. Is there a foolproof way to set desired status?
Regards,
Trestill
Hello @Trestill,
You're right, the order is not always the same. You should check the property Name of the profile, to know which is the one you need.
Kind regards.
Thank you Ernesto
costionofrei
