Extension still recording after disable recordings calls.
JMerces
After disable recording calls on extension, still recording calls.
Any solution or idea?
We have a Enterprise license.
Regards
Have you restarted the server ?
Yes, i restarted the server but still same issue on both centrals (we have 2 3CX).
  • 3CX Version: Enterprise 16.0.5.611
  • Server OS: Debian
  • Trunk Provider or Gateway Make/Model
You're not making tests calling another EXT which has recording enabled are you?
No. I just disable calls recording on one extension e making tests with that extension.
My extesion are enable recording.
We just have few people who need don't record calls.
What test are you making
Just disable call records in one extension and call to that extension.
External to internal? internal to internal?
Internal to Internal on same 3CX.
You need to disable recordings on both the extensions you test, then they should call each other
Support99
