- Joined
- Dec 19, 2007
- Messages
- 145
- Reaction score
- 0
Hi;
I have noticed strange behavior in my elastix system (asterisk 1.8.15)
From time to time, users are not able to establish connection from one extension to another one. They get busy signal, but the called phone has no connection in this time.
It's look like the called extension have established connection with his own extension during this behavior appears.
has anybody seen something like this and could explain what does it mean? ow to fix this?
Code:
Peer User/ANR Call ID Format Hold Last Message Expiry Peer
10.20.66.90 5814 [email protected] 0x4 (ulaw) No Rx: ACK 5814
Code:
* SIP Call
Curr. trans. direction: Incoming
Call-ID: [email protected]
Owner channel ID: SIP/5814-00009e7e
Our Codec Capability: 0x3c110f (g723|gsm|ulaw|alaw|g729|g722|h261|h263|h263p|h264)
Non-Codec Capability (DTMF): 1
Their Codec Capability: 0x10c (ulaw|alaw|g729)
Joint Codec Capability: 0x10c (ulaw|alaw|g729)
Format: 0x4 (ulaw)
T.38 support No
Video support Yes
MaxCallBR: 4096 kbps
Theoretical Address: 10.20.66.90:5060
Received Address: 10.20.66.90:5060
SIP Transfer mode: open
Force rport: No
Audio IP: 172.22.2.10 (local)
Our Tag: as1a065689
Their Tag: 629593614
SIP User agent: WPU-7800/00:03:2a:25:1e:c9
Username: 5814
Peername: 5814
Original uri: sip:[email protected]
Caller-ID: 5814
Need Destroy: No
Last Message: Rx: ACK
Promiscuous Redir: No
Route: sip:[email protected]
DTMF Mode: rfc2833
SIP Options: 100rel replaces replace timer
Session-Timer: Active
S-Timer Interval: 600
S-Timer Refresher: uac
S-Timer Expirys: 0
S-Timer Sched Id: 2883678
S-Timer Peer Sts: Active
S-Timer Cached Min-SE: 90
S-Timer Cached SE: 1800
S-Timer Cached Ref: auto
S-Timer Cached Mode: Accept
