External calls from ext.%1 is disabled by Administrator.
Iaan_Rossouw
Gold Partner
Good day
Why would the PBX disable a extension with the following error code?
30049External calls from ext.%1 is disabled by AdministratorWarningAdmin disabled external calls
System was upgraded last week Friday to Version 20.
For all extension or only one ?
Multiple extension
Check options in extension ( Admin > Users > edit user )
Reactions: fxbastler and bitn2
Thank I did turn that of. Just trying to find out why it would disable the extension.
Check the audit log, it was likely a human error, possibly confusing some options.
Alternatively, it could be a result of transitioning settings from v18 to v20, which I doubt, but it’s not impossible. There's no way to know for sure unless an investigation is done by comparing a v18 backup with a v20 backup.
However, I doubt it’s worth the effort since you can resolve this fairly easily, and it’s unlikely to happen again now that the v20 upgrade is complete.
Will check the audit logs.
Thank you hope this resolves the problem and that it doesn't happen again.
Also check on « Schedule » Tab
If this option is enabled, it will automatically check the other box when you are outside of business hours.
tom.walker@blackcountryra
