Solved External phone book can not be downloaded YeaLink SSL Problem?
Senox
Hello everybody,
I have already read a few existing posts on this topic, but nothing really worked.
First, I have to say that the maintenance of my 3CX has expired. It is also interesting that I suddenly get a SSL error with the 3CX-FQDN of my 3CX system. By entering the IP address and the port 5001 in the browser, I come on it but with a warning...
It works so far, however, the YeaLink phone is no longer able to download the external phonebook from 3CX. There is always the message External phonebook can not be downloaded. If I enter the URL XML in the browser with the FQDN link, I will not get an XML file. Probably because of the SSL error! However, if I enter the Provisionierungslink with the IP address instead of the FQDN it goes in the browser, with a SSL warning, but it shows me the contacts. But the YeaLink phone does not manage with either IP or FQDN. SNOM M300/M25 there it works with the Phonebook
Could the problem of the telephone book lie with the faulty 3CX-SSL FQDN? As a next step, I would try to extend the maintenance.
Any Ideas ?
Best Regards
Login into the phone web front end
Security -> Trusted Certificates - Change 'Only Accept Trusted Certificates' to Disabled
Thank you that's it, it works!
Hello @Senox
Please note that other services may stop working as a result of your maintenance expiring. You will also not be able to upgrade to newer versions with an expired maintenance.I would recommend renewing your maintenance to avoid future issues.
Bluebox Global
