Facebook int via webclient admin
Alphabetic
3CX MVP
hi guys
i'm trying to set up the facebook integration via the web client admin and i've managed to do it all but I cannot figure out the routing part.
How do I get facebook to send to my extension?
I can do it from the mgmt console but I have no way in the web admin to route the call to an extension.
this guide https://www.3cx.com/docs/manual/facebook/ just says to read the call handling manual..
You can set the Facebook integration as system wide or Part of Group.
  1. System wide - The trunk will be created and will be available ‘System wide’ (Default group).
  2. Part of Group - The trunk will be created within the chosen group.
Then remember that at the beginning you created a Test user. After the app is validated and approved by Facebook you can change this test user to another extension.
I assume the facebook set up requires the use of the webclient admin and mgnt console to get going? Thats the only way I could get it to go where I wanted it to.
mazet
