Faced with one way audio issue
Knight!
Good day Team,
I faced with issue like description here - https://www.3cx.com/community/threads/random-one-way-audio.75601/
but have different with Description in another topic
Two or three extensions has issue like one way audio ( only by using 3CX mobile Apps ) for same users Window 3CX Application work perfectly , but other working without a problem ( 3CX Mobile and 3CX Windows Client ) in different connection options
Could you please support me and give a settings advice i need to recheck for 3CX Windows V20 Server for issued ext . ?
I try to reset Ext are not working and re-provision them with Server ( Not help )
I try to delete Ext and Re-create it from zero for be shure all setting for account set as default ( not helped )
I try to set PBX delivers Audio ( not helped )
Try turn off SRTP for them
But unfortunately it doesn't help
Also i start to think about a mobile hardware version/model doesn't support V20 ( on V18 after setup UDP/RTP all starts to work without any voice issues )
FW setup is correct ( because other clients with mobile 3CX Apps can connect and talk without any issues ) on 18 and on 20 Verion of server .
Hello
first thing you need to establish is that your 3CX firewall checker passes.
Hello
Could you please tell me ( if know ) , for pass a FW checker, which host does the Server connect to check port access?
So your reply makes me suspicious that your firewall is too restrictive. Fix this, get the firewall check to pass and you'll be sorted.
tom.walker@blackcountryra
