Failed to Update to 16.0.2.910
rubennazarian
3cx is not able to get the latest version!
Reading package lists...
Building dependency tree...
Reading state information...
The following packages will be upgraded:
3cxpbx
1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
Need to get 93.9 MB of archives.
After this operation, 189 kB of additional disk space will be used.
Err:1 http://downloads-global.3cx.com/downloads/debian stretch/main amd64 3cxpbx amd64 16.0.2.910
403 Forbidden [IP: 35.201.76.132 80]
W: --force-yes is deprecated, use one of the options starting with --allow instead.
E: Failed to fetch http://downloads-global.3cx.com/downloads/debian/pool/stretch/3cxpbx_16.0.2.910_amd64.deb 403 Forbidden [IP: 35.201.76.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Rollback to 16.0.2.900...
3cxpbx is already the newest version (16.0.2.900).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
what should I do?
Strange that the repo is giving you a 403 Forbidden error.
I just tried to pull that file from them, and the web server didn't return with an error.
The same for me , clicking on link included in your first post give me access to DL the file with no problem
Hi Ruben,
I think the forbidden IP should be the first sign to note.
Also wondering why you are attempting to update via the command line instead of the management console?
Reactions: cparker_RCT
Would there be any ill effects doing it that way?
The Linux nerd in me would want to do that, simply out of habit.
Hi Ruben,
Hi Ruben,
I tried it from the console !
Sorry I thought you pasted terminal output. When pasting logs please remember to always state where they came from exactly (ie. Terminal? Activity Log? Specific 3CX service log?)
Yes please avoid doing upgrades manually via terminal generally speaking. Via the management console we have control of conditions before updating anything and do not proceed if conditions are not met.
Manually updating 3CX via apt upgrade would force an update even when not advised and increases the possibility of breaking the system, simple example: you are on Debian 8 and force update your 3CX to V16. The system will break because the dependencies that V16 relies on are only installable in Debian 9.
So where is this log from exactly and what version of Debian and 3CX are you currently running on?
bosdorf
