Failover / HA sensitivity
Jeffrey Hirth
Is there any way to adjust the sensitivity of Failover / HA?
Our set up is working great except that it fails over practically instantly. This causes the failover to occur even when the primary server reboots for regular maintenance, which is only about 45 seconds.
Is there some way to set failover to occur only after x number of consecutive fail events?
I see it's possible to control how often the tests occur, and the default is 30 seconds. But that doesn't really help me. Even if I extend that timer out to 120 seconds, for instance, I still run the chance that it tests during those few seconds when the primary is rebooting and then triggers failover.
Hello @Jeffrey Hirth
Currently the only things you can adjust are which services are monitored and the interval these checks take place. You could disable failover for scheduled maintenance. Alternatively i would recommend posting this as a feature request to our ideas section of the forum https://www.3cx.com/community/forums/3cx-ideas/ . All posts are reviewed by their corresponding Departments and, if feasible and voted for by other users as well, may be implemented in an upcoming service pack or update.
jmarshall
