Failover LANtoLAN script Linux
Riccardo M.
I've to add a second 3CX (Linux Debian) server on our network that has to work as Passive. I don't know how to proceed with the configure of the scripts to insert here:
the Backup/Restore are already configured..... otherwise I've run that commands on Passive:
root@lab-pbx01:~#: ssh-keygen -t rsa
root@lab-pbx01:~#: cat.ssh/id_rsa.pub | ssh root@XX.XX.XX.XX "mkdir -p ~/.ssh && chmod 700 ~/.ssh && cat >> ~/.ssh/authorized_keys"
someone can help me? thanks
It would be best to use internal DNS and use a script to update the DNS to the IP of the passive server upon no response from the primary server.
we have as internal DNS a W2019... so the steps to run should be:
  1. stop the services on Active:
    1. sudo /usr/sbin/3CXStopServices
      sudo ip l s eth1 down
  2. run the script to update DNS record
    1. ????
or create a script to change the IP address on Passive ????
      sudo ip link set ens92 down
  2. run the script to update DNS record on windows
    1. ????
or create a script to change the IP address on Passive and put that in up????
  1. change the IP address
    1. sudo ip a add 192.168.1.200/24 dev ens92
    2. sudo ip link set ens92 up
is it correct to use only the script /usr/sbin/3CXStopServices to stop all services of 3CX or I've to consider someone else??
the script to use is right in this way?
#!/bin/bash
ssh -t 10.20.74.26 /usr/sbin/3CXStopServices
ssh -t 10.20.74.26 ifconfig ens192 down
ifconfig 10.20.74.26/24 dev ens192 up
last question :-) is better to add that before or after to start the services? thanks a lot. Sorry but for the failover LANtoLAN I've found few posts.
tohoken1
