Failover notification
DXC
Hi there,
How can I get a notification when the passive server becomes the active one?
It's an automatic process, but I need to switch it back manually when the main server is available.
Is there any way to switch it back automatically?
I'm afraid there is no built-in way to allow notifications for a failover event to be sent nor is there a built-in way to automatically switch servers back, but you should be able to do both by utilizing the "Failover Script Operations" within the Failover settings. Developing the scripts and getting them to work is of course up to you but you may find some "Windows-based" sample scripts here: https://downloads.3cx.com/downloads/misc/FailoverExampleScripts.zip
Additional info here: https://www.3cx.com/docs/failover/#h.nod9zuqmoydm
florentrobineau
