Failover script
Hostname
SOHO User
hello
I just wanted to ask if anyone is using failover scripts under Linux?
Yes, I use failover scripts with Debian PBXs. Specifically I use one to update internal DNS and a NAT rule on the edge firewall.
there is and example script for update internal DNS i have 2 pbx with linux and 1 windows server "dns server"
I do not think there are any published example scripts that do that.
I guess I'm not sure what you are asking for. A simple Google search for linux script will give millions of exampls. A more refined search will give more specific examples. Scripts in linux is not 3CX specific. Look for as script to do whatever it is you want to do and then you tell 3CX to call it.
That uses virtual IPs tho, which I don't think is "supported" for 3CX Failover, just so you know.
yes i know it's not supported but im happy with that its more better then failover configuration.
gmacinit
