Failover
broaton
Platinum Partner
Greetings everyone.
Does anyone have a good solution, to do an onsite server (windows version), with a cloud failover? I read this doc (https://www.3cx.com/docs/failover/) but it states that it's really not supported.
I would of course upgrade there pro to enterprise version.
I got a customer wanting this bad.
Thanks!
Barry
What exactly in your mind constitutes a good solution? The document there outlines everything that you need to do. It's just not supported. No amount of 'goodifying' is going to make it supported by 3CX
Well, I was hoping someone had found a more inherent way, then have to do all the .bat files and such.
SCarpenter@fifthavenue-la
