False Harddisk Warning?
I saw a couple of thread about false harddisk warning, but they really didn't settle on a cause or solution. Anyone else seeing this? Mine started w/ the last upgrade. The error message is:
3CX installation 3545.3cx.us is running out of space. (456.3 Mb Space left out of 500 Mb).
As a result of this, recordings, logging and voicemail services are disabled until this problem is resolved.
Login to the machine, free up some space or add more disk space and reboot the server.
Below are the dash stats:
12999
Below are the disk usage stats from my instance:
Filesystem Size Used Avail Use% Mounted on
udev 991M 0 991M 0% /dev
tmpfs 201M 24M 178M 12% /run
/dev/xvda1 7.9G 5.1G 2.3G 69% /
tmpfs 1002M 12K 1002M 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 1002M 0 1002M 0% /sys/fs/cgroup
tmpfs 201M 0 201M 0% /run/user/1000
I'm not seeing any reason why the server is detecting a space limitation. I did see mention of a 500mb limit. Is this limit a parameter that we can change?
My recordings quota settings:
13000
Perhaps i'm wrong but in your screencopy, quota is set to 5GB and on HDD only 2.3Gb remain free
Wecare_ITA
