Fanvil i10V support.
kseba77
Any plans to add official support for Fanvil mini intercom i10 series? Specifically looking at i10V.
If yes do we know when?
Also any of you have successfully installed the mini intercoms with 3cx?
thank you
The UI looks identical to pretty much every other Fanvill Doorphone so I wold be surprised if the provisioning template differs very much (if at all). Nearly all I have seen (admittedly only about 4 models) are all the same and there's very little to the template.
You can try and provision it as an i30 (or similar) just upgrade the firmware first and for obvious reasons don't apply any updates from the control panel. Alternativly you can make a new template and add the
model number you want where applicable.
If you use the Fanvil i20 the door video phone work great with the i10v. We only have tried the Video, not the door release.
The door release is normally triggered by DTMF tones so shouldn't matter what template is used as long as you can get it to register.
hughesdouglas
