Fanvil PA2S
dpcinc
Gold Partner
PA2 stock is out at several distributors. But the PA2S is in stock. Has anyone tried the PA2S instead of the PA2 using the PA2 template for provisioning and had success? I have a simple amplifier to speakers setup and the PA2 would work fine. What about the PA3...does anyone have experience with them? I've just never used them.
Update 4 has support for Fanvil PA3. Compare its specs against the PA2 to see the differences, but you can mostly use it as a replacement.
