Unsupported Fanvil x210 external ringtone
pbomboy
The 3cx interface does not list this field or at least I cannot find it.
I found the option in the phone's web interface under Media settings, Alert Info Ring Settings, External. But when the phone gets re-provisioned it will loose this change. Can I create a custom template to resolve this.
Hi @pbomboy
Yes can change it using a custom template, but it will still not appear as a field to edit from 3CX.
You would simply be hardcoding it to a different ringtone than the current one.
Hi @pbomboy
I can live with that, do you have any examples I can follow?
Unfortunately no but we offer this guide here explaining how to create custom templates.
Please read the last part at the end of the page though, to be aware of what using custom templates means for you as a customer before you choose to go ahead.
https://www.3cx.com/docs/custom-ip-phone-templates/
Diogo Maia
