Fanvil X4 phones
frog
HI All, has anyone else had experience of these phones. We are receiving complaints that the phone is crashing. So the screen goes blank and the Lan port for the PC stops functioning. A simple reboot fixes the issue.
latest 2.4.0.5572
On different switches. Even different offices.
latest 2.4.0.5572
Hi frog,
Are they using the PoE switches? I'm asking because the Fanvil phones are very sensitive with the power.
I saw the similar problem long time ago on my customer's side who was using the Netgear PoE switch.
That switch wasn't providing enough power to the Fanvil phone and it was freezing.
We replaced the PoE switch with the regular one and connected the phones using the power cables - issue was fixed.
Try it, probably it will fix your problems.
Reactions: YiannisH_3CX
WagnerFT
