Solved Fanvil x7 Firmware is not supported
Emam
Greetings All, I want share with you My fanvil Ip phone firmware is not supported . I tried to update Firmware From 3cx but its not fixed after restart phone has same problem.
If it doesn't work, factory reset the phone.
Download the correct version from here https://www.3cx.com/support/phone-firmwares/
Then login to the phone web interface, and upgrade it manually.
When done, you can assign it in 3CX again and it should now be ok.
Reactions: Emam
I will try .Thanks For response.
Now Firmware has been updated. Thanks again.
Reactions: JohnS_3CX
No problem! Whenever the next release comes out for the X7, you should now be able to upgrade it via 3CX because you are on the latest.
Diogo Maia
