Fax Extension Outbound Number
mercury3
I configured a PATTON SN4148 for Fax with FAX extensions.
Each of its FAX extensios has a different outgoing number but it is not integrated during an outgoing FAX, it is the main number of the trunk that is taken.
I saw on this subject (https://www.3cx.com/community/threads/fax-default-caller-id.52589/) that the bug is known. Do you know if this problem will be solved soon?
PS: I use "Originator caller ID" so that the correct number is displayed during a transfer on mobile.
Thank you for your reply.
Hello @mercury3
Please note that the fix for this will most likely be included in the next service pack release coming soon.
Hello YiannisH_3CX,
Okay, I hope because we will soon migrate all our faxes on our SIP Trunk and so on 3CX.
Thank you.
gmacinit
